Brief Description: Closed up left elevator (almost)
Rivetted bottom spar of the left elevator to skin. Rivetted tip- and root ribs to skin, rivetted trim spar to skin and (via gusset) to root rib. As with the right elevator, used a combination of pop-rivets and solid rivets on the bottom spar-to-skin joint.
Next: Drilling holes for the (elevator side) of the trim piano hinge.
