Brief Description: Dimpled elevator skins; Fitted rudder
Dimpled all holes in both elevator skins.
Test-fitted the rudder to the HS. Checked the maximum deflection: 33.7° right, 35.5° left. Looks OK for now. Could get a bit more if the trailing edge skins on the rudder are sanded away a bit. But have to see until the plane is finished for that.
Next: Scuff and de-grease left elevator parts for priming.
