Brief Description: Dimpled/CS left elevator spars and root rib
Dimpled left elevator spar, root rib and bottom of elevator trim spar. Countersunk the top of the elevator trim spar. Some CS holes ate too much into the material, I'm not particular happy about these. On the other hand, the trim tab hinge will be mounted below the upper trim spar flange. Deburred the edges of the whole left elevator.
Next: Dimpling the remaining holes on both elevator skins.
