Eds Vans RV-6A/7A Web Site
Date:  1-7-2018
Number of Hours:  0.00
Brief Description:  Attaching the control surface horns and hinges.
Added all the control surface hinges and control horns.
To install the hinges you must first -
1. use a soldering iron and melt away part of the Velcro gap seal.
2. using the soldering tip to expose hinge pilot hole.
3. rivet the first hole.
4. drill a second hole.
5. rivet that second hole.
6. drill the third hole.
Installing the control horns is exposing the bolt hole with the soldering iron tip.
Control horm attachment.
Control surface hinge instal.
