Drilled the counterbalance weight to the end rib and counterbalance rib structure. Removed the weight and reassembled the structure to the end spar. Drilled the root rib to the spar. Clecoed the skin to the spar. Drilled the control horn to the spar and root rib. Drilled the trim tab spar to the skin and root rib. Drilled the skin to the root rib, trim tab spar, and half of the main spar. Drilling will continue next session.
Root Rib Clecoed and Drilled
Trim Tab Clecoed and Drilled
End and Counterbalance Ribs Clecoed and Drilled to Spar and Skin
