Brief Description: Drilling the HS Spar for Nut plates
Set the nut plates for the Spar horns and drilled them for riveting. Used an AN3 bolt with a large hex nut and flat washer to hold the nut plate in place for the first hole and then clecoed the first hole to drill the second.
