Brief Description: Still working on the Anti-Servo Tabs
I started early this morning working on putting the final touches on the Anti-Servo Tabs. I attached the spar for the left and right side using blind rivets. I also started working on the hinge pieces which consumed the rest of the building day. They don't tell you that you have to drill 60+ #30 holes using a snap in guide until you are right on the part where it seems easy. Drilling holes in a piano hinge is very tedious and time consuming. I have a drill press but that was not conducive to this operation. I have completed it but it was too late to rivet the hinge and complete the section today. I will get it done by Tuesday, my oldest Granddaughter’s birthday is tomorrow so I will not be able to work on the plane.
