scuffed up right aileron parts with scotchbright pad. pulled out parts for the flaps. Deburred both spars and all the ribs for the flaps. Assembled skeleton for the left flap and match drilled. Clecoed on bottom skin and match drilled the aft spar holes. No shims were required. Drilled the ribs to the bottom skin. Clecoed right flap skeleton together. David helped rived 2 of the ribs to the top skin on the left wing.
