I finished up making the right hand rib #9 assembly. This required attaching the right hand bellcrank assembly (SNX-W21-02R) and the vertical channels (SNX-W21-13R/14R) to the right hand rib #9. I also had to attach the clips (SNX-W21-09) to the vertical channels.
The hard part of doing this assembly was getting the parts mounting positions properly marked on the rib. Once this was done, it was fairy easy to drill/updrill the holes for the rivets. I noticed that the vertical channel flanges were not bent to a 90 degree angle, as they should. I cleaned these up with my small metal brake before rivetting them to the rib.
Channel flanges not bent to 90 degrees.
Rivetting up the parts.
Parts all rivetted up and the flanges are now at 90 degrees.
