Brief Description: Studying plans and figuring out rivet placements
I spent most of the day studying the plans to figure out what rivets are needed in the various locations on the wing spar. I needed to flip the spar over and moved all of the clecos to the up side so that it will be easier to drill/countersink the holes for the various rivets/screws on the spar.I also came up with a color-coded system to keep track of the different rivets and marked those locations on the spars. I hope this works as there are many different rivets/bolts/screws to keep track of.
Spar flipped over and clecos moved to the up-facing side.
Color-code system for keeping everything organized.
