Today I made up the SNX-W23-02 probe assembly. I used the pre-made pitot/static probe from Aircraft Spruce. Mainly, I had to make up the mount plate and the tube support angles, then assemble the unit. This will be installed later when the wing is done.
Laying out the mount plate.
Drilling out a 3/4" hole in the center of the plate.
