Brief Description: Part #SNX-F23-03/forward lower mount angle
I made part #SNX-F23-03 tonight. I had to open the angle up to 95 degrees. I used the large adjustable wrench method to do this. The rest was pretty straight forward. I rough cut the rounded slot and finished to size by filing. Marked and drilled the pilot holes.
Angle marked for side cuts.
Round slot cut out and angle marked for pilot holes.
