1st picture is of the right side static air vent attached with pro seal. I then decided to measure and bend from .063 aluminum the avionics shelf. I plan on attaching the vertical power electronic circuit breaker box on the right side, with a raised bracket to allow for the remote com GTR 20 to be placed underneath. I left ample space on the left side to allow for the scat tubing for the fresh air vent to clear. I also, attached the shelf with plate nuts for ease of removal if needed. There are several other items that will be placed on the shelf when I start the Avionics install at a later date.
