Tims Web Site
Date: 3-27-2016
Number of Hours: 3.00
Brief Description: Prep for top coat interior fuselage
Had a few areas where some loose debris made it into the surface. I thought I had prepared really well, however, this time after a light sanding in a couple areas, I used compressed air, prewash, vacuum the interior, and finally tacked off all areas before top coat. Turned on booth fan a good 10 minutes before painting to start. Shook paint, Mixed all required parts, let stand required time, got gun ready to spray. The top coat being satin finish, will dry quicker than the primer. Painting went well without any problems. I got a good tack coat followed by a cross coat. All is covered. Now the wait to dry.
Little sanding of light debris
Tack coat
Followed by cross coat all interior
