Brief Description: Temporarily installed, match drilled, deburred Hin
I also temporarily installed the outboard Aeiloron hinge bracket, along with the aeiloron and flap gap seals. I match drilled all to the rear spar, removed and deburred the drilled holes. I then re clecoed back on the rear spar. Next to drill, deburr the hinge pieces, scotch brite all parts to get ready for primer.
