Brief Description: Finished Riveting the Right wing top skins
Larry came back over to help finish the outboard top skin on the Right wing. Took about the same 3.5 hours to finish. After he left, I removed the Left wing tank and wired up the sender with 2 conductor shielded wire 20 gauge. I Had to remove one of the sender attachment screws to install the ring terminal. Decided to leak test again to be safe.
Finished riveting top skin for right wing
retesting tank after screw removed and reinstalled on sender
