Brief Description: Start of Wing assembly of ribs and rear spar to ma
Start of wing assembly with rivets. Layed out all wing ribs proper orientation, With the help of a friend, started riveting the ribs to the main spar. I found that it was better to have an extra pair of hands to do the bucking. With an assistant, the wing ribs went really fast. Only took 1/2 Hour to rivet the 14 ribs. Helper couldn't stay, however, I went ahead and installed the rear spar. these rivets were installed with a squeezer.
Riveting Wing ribs to Main Spar
After wing ribs are riveted to spar/ attaching rear spar
