Brief Description: Finished the access opening on the left wing/ adde
The access panel opening on te left wing was designed for the Stall warner access. I have decided not to use the Stall warner from Vans, and instead use the Angle of attack features within the Garmin G3X. Therefore, I have closed up the rivet holes on the leading edge of the left wing. I will use the access panel to access the rear of the fuel tanks, as I plan on installing the Bungs from Hotel Whiskey Extended range fuel tanks. This way, I will have access to the required fuel pump and fittngs for the extended range tanks. I used the supplied from Vans Mounting and cover plate, and duplicated them for the Right tank access.
Right tank access hole cut adn drilled
Duplicate access mount and cover
Getting ready to prim the inside of the leading edge skins
