Brief Description: Finished pre assembly of fuel tanks
Final pre assembly of both left and right fuel tanks. Cover plates drilled, fuel pickup fittngs installed, Vent lines pre installed with hanger brackets, Flop tube fitting an flop tube installed in Left wing tank. Set fuel tanks aside awaiting fuel tank sealant to arrive from Vans Aircraft. Started dissassembling the wing ribs from the rear and main spar. Next to scotch brite rear spar and wing ribs, alumi prep, alodine and prime.
