Brief Description: bent and prefit vent tube for left wing tank, alon
got all fittings for the left and right tanks for the vent tubes. cut to fit the vent lines to reach from fittings to just shy of the outboard rib on the wing tanks. Made a small attachment fitting to hold the vent tube to the fuel cap as per plans. Put fittings on lines and flared 37 degree fittings as required. repeated the same steps for the Right tank.
