Brief Description: Fly cut rear baffle for left tank, dibpled skin, p
Drilled the cover plate for the left wing tank for the fuel sender nutplates. Fly cut the cover plate attachment ring opening in the baffle for the fuel sender. I will have to close off the fuel pick up opening in the cover plate, since the flop tube is placed in the front of the inboard rib thru the attachment angle.Dimpled all the left tank skin along with the stiffners for both tanks. Preassembled the left tank complete with flop tube and ready for sender installation and setup.
