Brief Description: Installation of nutplates on main wing spar
I had previously drilled and countersink the tank nutplates on the main spar. primed the removed countersink material area with rattle can primer. Now installing the nutplates and riveting on with a pneumatic squeezer. After setting the depth of the squeezer, attaching the nutplates was like an assembly line process. went really well. After installation of the nut plates, I drilled the inspection plate attachment nutplates #6 and installed as well. Next was to cut the 1 x 1 x 1/8" angle material for installation on the wing jig posts installed earlier.
