Brief Description: Installation of elevator trim tab servo
Installed the elevator trim tab servo. Adjusted the travel with a 9 volt battery to operate the servo. As per instructions, I installed the servo control clevis ends on the all thread and bent to the proper degree as to allow for full movement with battery, an also to make sure no binding was observed during the process. After installation, I checked the range of motion with a digital angle device. Up movement, which will lower the tail was 42 degrees. Down movement which will raise the tail, was 10 degrees
Original setup of installation of servo mount to servo bracket
Trim tab installed with temporary hinge pin
Trim tab installed with servo motor an control horn in place
