Picture 1 shows alignment test for final assembly check. Picture 2 shows inline of trim tab with elevator trailing edge as to remove any twist before riveting. After final test fit, all riveting was completed. Picture 3 shows finished trim tab installed with temporary hinge pin installed
Alignment of trim tab trailing edge with elevator trailing edge
Final fit of trim tab to remove any twist before riveting
