Tims Web Site
Date:  11-9-2015
Number of Hours:  4.00
Brief Description:  Made troughs for alumi-prep/alodine
Bought 10" pressure caps in PVC for 10" PVC pipe. I used waterheater pan drain fittings for the ends along with 3/4" pvc ball valves for drains cocks. The 10" pipe is 6'2" in length to allow for any long items to be completely submerged. After glueing the end caps on, I used a skill saw to cut the pipe in half. I then fabricated the base mounts to hold each half. I plan on setting them on the mobile base I used to get the fuselage to the shop on. The total height is 2" above a standard 5 gallon bucket. This allows me to put the parts in each for the process of alumi-prep then Alodine.
I've determined that 10 gallons of solution will submerge any needed part so far. The process is pretty simple, submerge scotch brite scuffed parts in Alumi-prep for 5 minutes. Then, Remove, rinse off with water, place in 2nd trough of diluted alodine for 3-5 minutes. Rinse off, let dry. They have a light golden color. This is the first step in corosion proffing the aluminum. The plan afterwards is to apply the Sherwin Williams P60-G2 Wash primer. When parts are completed to the last an final assembly mounting, I plan on Epoxy priming befor painting with single stage top coat. Final brand of top coat paint to be determined in the near future.
Drain an leak test
Drain an leak test
close up view of ready to use troughs
