Brief Description: Received the Panel from Stein Air
I received the Cut Panel from Stein Air. Mounting brackets were in the box to be installed per there instructions. There were 2 locations 1 in the corner of the Auto pilot opening and the other corner of the Audio panel opening that I need to remove with a Dremel. The most shown area is in picture 1. Picture 2 is of the openings being removed with a dremel. Ready for Aloding and assembly.
