Brief Description: Installed master contactor and firewall pass thru
I received the master contactor from Aircraft Spruce. I had mounted the nut plates on the front side of the battery mount. I had to remove and reinstall on the rear to allow for the installation of the contactor. Temporarily installed and drilled the battery mount for the battery cable. Removed and installed the Cable terminal. Picture 2 is of a marine bulkhead pass thru. Which I will use on the firewall.
