Tims Web Site
Date: 2-29-2016
Number of Hours: 6.50
Brief Description: Battery tray modification for transponder/ELT
I saw a brief picture online of a battery tray modification. Went to find again and wasn't able to locate. However, I got the just of the modification and decided that this would be a great place to install a remote Transponder and ELT. Space is limited in the RV8. I dialed the thickness of the battery tray to be .063, so that is the extended base material used. I first got online to find out the dimensions of the Garmin remote transponder that I plan on using. The 23ES. Also the ELT I will be using is the Artex 345. With these installation dimensions, I decided to make the tray with both sides to have a platform of 4.5 x 11. I was not sure if the .063 would be stable enough, so I reinforced the underside with 1/16" thick 3/4" angle stock. The tray is within 1.25 inches from the side longerons if not sturdy enough. I can attach small angle stock to the sides to make more stable if necessary. After assembly, with the additional angle, it seems really sturdy. Happy so far, I will have a friend of mine double check. Also, upon installing the angle, I had to drill rudder cable access holes to allow the clables to pass thru. No problem, the angle is just big enough to allow for another snap bushing.
Cut out of .063 base materila
All angles clecoed in place
Finished assembly, all riveted
