Decided to install the forward baggage door panel access door. Was undecided, Not sure if it will be needed, but it would be difficult if not impossible to do later. So, away we go with the panel access door. First I cut out the proposed door from construction paper. Then transfered the final door shape to the fuselage. It took a lot of dremel cutoff blades to cut the opening. Seemed that when I got to cutting, the blade would bind and shatter. Finally after 10 or so disks, the opening was cut. Then I took the door template and transferred to another pice of construction paper and added 1/2" over size. Then from that mark, undersized 1". This template will be used for the doubler.
