Brief Description: Drilled riblet holes on elevator and build shim
Finished up the riblet today. I deburred all 3 riblets and match drilled the holes for the elevator riblet. the riblet on the elevator had a slightly smaller profile than the shape of the elevator so I bulilt a shim to lay on top of the riblet. With the shim and some scotchweld it will fit perfect.
Handy tool for getting perfectly spaced holes
Had to use my long drill bit to drill the hole from the rear riblet flange to the spar
