Brief Description: Match drilled skin and built riblet
I match drilled the skin to the under structure and finished building the last riblet for the elevator.
I built the riblet the same way as before. Used some thick paper to get an outline. I then transfered the image to another piece of paper and drew on the flanges. After I cut out the template, I used my hand seamers and bent it up for trial fit. Once everything was fitting like a glove I transfered the template to a piece of aluminum and started the process over.....trace, cut and bend.
Match drilling skin
Transfering profile to thick paper and drawing in flanges
Using hand seamer to bend rib cut out from the aluminum
