Brief Description: Propeller flange bushings, 1" spacer and backing p
Continuation of the propeller spinner and backing plate fitting:
The gear reduction flange gets 6 bushings inserted to accomodate the appropriate bolt size for the Warp Drive hub unit. These bushings actually nest into the 1" spacer unit, which in turn has matching bushing installed. The spinner backing plate then slides on over the bushings.
The bushings that go into the gear reduction propeller flange are press fit, although very little force was required to seat them. The photos below show the gear reduction propeller flange with the bushing inserted, the 1" spacer unit in position, and then the spinner backing plate postioned.
Continued on the next post (I am limited to three photos per entry).
