Brief Description: installing the prop to fit the spinner
Continuing the installation of the prop/spinner assembly,
I had to assemble the propeller unit. I have a Warp Drive three-bladed unit. The first photo shows the blades sitting in the two halves of the hub unit as I am threading the nuts and bolts into place. Next the spinner base plate slides on over the extension unit, then the assembled prop/hub unit goes into place, with the crush plate and mounting bolts following. The second and third photo show all of those parts in place.
I can now measure the prop blades and the spinner backing plate to determine how deep to make the cutouts in the spinner unit.
