Brief Description: Fitting skylight and associated mounting hardware
Today I did more work fitting the skylight lexan panel. Once it was fitted I match-drilled the holes in the lexan to the support ribs and cleco's the lexan in place. Next I trimmed the aluminum strips that are installed on top of the lexan, and which the securing rivets go through. I marked out the strips for holes, and started to drill and install them, running out of time half-way through the job.
