I finished and installed the ELT mounting plate/floorboard extension. The ELT sits in an aluminum tray and is fastened in place with a band-clamp unit. The ELT also has a pair of velcro straps that will hold the portable antenna for the unit.
The antenna is mounted on top of the fuselage just aft of the rear passenger on a factory provided mounting plate.
