Brief Description: Install left wheel/brake assembly
We cleaned the bearing and packed them with grease, then installed the wheel assembly. This took several attempts as the way I originally aligned the brake plate would have interfered with the gear fairing. I had to remove and reinstall the axle/brake plate assembly to rotate the brake assembly to a lower position giving clearance for the fairing.
