Installed the fin intersect fairing - glued a peice of alloy into the hole whewre the jack screw would be threaded into. This can by punched out of place if required and makes for a neater fabric seam.
The elevator trim screw jack assy was attached to the trim motor via the collect - coupler, and screws inserted with threadlocker and lockwired into place
