TAB Aircraft LLC Web Site
Date:  4-18-2015
Number of Hours:  0.00
Manual Reference:  N/A
Brief Description:  Page 507 Fixed Coolent Tank
April 19 2015
Fixed Coolant Tank
So after a few flights with the larger Coolant Tank and never seeing the level change, I got back from the SeaRey Fly-In and looked at the level and saw coolant had leaked on the Turtle Deck.
I quickly took off the Cowling and found that the coolant had leaked through the fill plug.
I figured the hose to the Coolant Tank was blocked. I took off the hose to the Tank and blew into it to see if bubbles would blow into the tank, but I could not blow into the tank.
I removed the Tank and found the hose connection had never been drilled through. Now I think that the pressure build up with no Overflow Tank to take the pressure off might have caused the Heater Control Valve to fail.
I drilled the connection ant put everything back together and hope this will end my coolant issues.
