Brief Description: Page 322 Repositioning the Cowling
August 22 2013 continued.
I did not like the position of the Cowling after I drilled out the mounting holes for the rubber grommets. I removed the grommets and moved the cowling till it lined up with the Spinner and then drew a circle around the mounting post. I removed the Cowling and taped the holes and laid in fiberglass from the inside
