With the labelling done, All that is left to do before installing the Windshield is the Dynon wiring. At the suggestion of Jim Ratte of Recreational Mobility, I went with the FastStack Wiring System http://www.approachfaststack.com . It connected all the Dynon items together and gave me the pre-wired Headset Plugs and wiring to the Radio Mic Key Buttons on the Control Yokes. After plugging all the FastStack plugs into the Dynon Items and to the FastStack Hub, I just connect the Power and Ground pigtails and every thing should work. Next is connecting the Engine Sensor wires to the Dynon Engine Sensor Cable
Installed the Engine Sensor Cable plugs front and back
