Earlier in the week, Bill Starkey came over to help me install the wings. It did not go well. The Wing Spar would not fit into the Spar Yoke, and two middle aged men is not enough to hold the wing up and try to maneuver the wing into the proper connection points. Even with the help of the next door neighbors it became apparent that things were not fitting and we gave up for the day. I ended up having to ream out the plastic inserts in the spars and filing down the Attachment Block on the Strut to get it to fit in to the Upper Bulkhead Cross Tube. I then had to wait till Saturday to ask for help at the EAA meeting. Four of the members came over to help and that turned out to be the right number needed to in stall the wing and the Wing to Tail Cables.
Section 34 Attaching the Wings to the Fuselage Manual Ref: 1.1 to 5.3
