Brief Description: Page 200 Installing Control Horn on the Elevator
March 5 2013
Section 25 Installing Control Horn on the Elevator Manual Ref: 5.1 to 5.6
I needed to remove the Elevator to install the Control Horn. The Gap Seal had to be cut to be able to slide out the middle bolt. Once the bolt and the Elevator was removed, I cleaned up the cut on the Gap Seal, and installed the Control Horn on the right side Elevator. While the Elevator was off, I checked all the Hinge Bolts for torque and reinstalled the Elevator to the Stabilizer. I connected the Control Arm and got to play with the Control Stick.
Had to cut the Gap Seal to remove the center bolt on the Elevators
