Brief Description: Page 436 Tried to do some wiring
December 24 2013 CHRISTMAS EVE
While waiting for the phone to ring with plumbing jobs, I tried to do some wiring. I did not get any plumbing jobs all day, and I did not get much done with the wiring. Most everything is wired and working, but without a proper wiring harness and running one wire at a time I ended up with wires crossing other wires, some with to much slack and some with not enough slack. When I started to lace up the wires behind the dash, I soon found out that it was not going go together very neatly. I disconnected all the Dynon/FastStack cables and tried to untangle some of the wires, but gave up on that. It looks like I am going to have to cut the lacing I have done and unplug one wire from the ACI Power Buss and/or from the Ground Buss at a time and pull it out of the mess and reconnect it back, before I can lace (wire tie) it back into a proper wire harness.
I moved on to work on getting the Panel Light Dimmer to work. I removed the Dimmer Switch and installed the Power and Ground wires on the Input and Output side.
