Brief Description: Page 426 Mounting the Dynon Pitot/AOA Probe
December 14 2013 continued.
After marking the Probe where the mounting rivet needed to go, I carefully drilled a hole in the Probe without getting into the tubes inside. I then glued a couple of washers inside to keep the Probe centered when riveting. I installed the Probe and riveted it in.
Carefully drilled a hole in the Probe without getting into the tubes inside
Glued a couple of washers inside to keep the Probe centered when riveting
