Brief Description: Page 334 Making the Viking Switch Panel
September 3 2013
I extended the rest of the switches and drilled the holes in the left side wing panel. I was not happy with the holes I drilled. They did not line up straight and one hole was to big. The Key Switch ended up to close to a Switch Guard, so I cut out a new panel out of some scrap aluminum and re-drilled the holes more carefully.
I then decided to put the Hour Timer on top to fill out the panel.
All the switches extended
First attempt, Key Switch is too close to the toggle switches
