Brief Description: Page 77 Installing Trim Position Sensor
September 20 2012
I Installed an Adjustable Control Rod for a Radio Control Airplane I got from a Hobby Store on the Sensor Arm, and two sided tape on the top of the Sensor and set the Sensor up side down on the Actuator. I ran the Actuator back and forth to test where to set the rod on the Trim Slave Arm. I marked the spot for the hole on the Slave Arm. I removed the Slave Arm and drilled the hole and reinstalled the Trim Slave Arm. I inserted the Rod and test run the Actuator and adjusted the Rod till it pushed and pulled the Sensor Arm full in and out.
