The length of the Canopy Brace and the Canopy plastic sheet was to long to let the rear brace to seal against the seal on the Turtle Deck. I used that fact to make an improvement in the setup by drilling holes in the Upper and Lower Canopy Guides and inserting the Front and Aft Canopy Braces into the Guides to make sturdier assembly. The Plastic Canopy Sheet will now need to be trimmed at the top to keep the Canopy from bowing out from the Turtle Deck.
Drilled holes in the Upper and Lower Canopy Guides
Inserted the Front and Aft Canopy Braces into the Guides to make sturdier assembly.
The Plastic Canopy Sheet will need to be trimed at the top
