Brief Description: Page 431 Insulating the Heater Pipes
December 18 2013
While running the engine to see the Dynon Gages work, I ran the heater since it was cool out. Checking the aluminum pipes I used to run from the back to the front I found they got pretty hot and I had some wires and Brake Line tubing touching at the front. So I got some Pipe Insulation and covered the pipe before I permanently installed the Cockpit Side Covers.
Cockpit side tube (Bottom) with the Heater tube (Top)
