With all the Avionics in, it is time to attach the LSX Panel to the Hull. With the forward deck temporarily set, I set the Panel against the Deck and drilled through the Hull Side Angles into the side of the Panel and fed a screw from the inside of the panel through the hull and installed the nut. I did the same on the other side. I then drilled two holes on each end of the top center hump and into the top of the Deck and installed screws and nuts.
Drilled through the Hull Side Angles into the side of the Panel and fed a screw from the inside
Drilled two holes on each end of the top center hump and into the top of the Deck and installed screws
