Brief Description: Page 245 Mine is better than yours
May 18 2013
If you buy the LSX CENTER CONSOLE AND COCKPIT SIDE PANEL KIT, you get a couple fiberglass Instrument Panel Extension that are poorly made and do not mirror each other and ruin the look of the interior. I told PA not to give me mine till they fix the problem. They came up with just making them over sized so they can be cut to size. I got these over size fiberglass pieces and saw that they still can't be fixed. What to do? Make it your self. Luckily, I had some Pylon Side Cover Aluminum panels that I messed up on and replaced. It's the same gage aluminum as the interior side panels and is easy to work with. I cut a piece and started to trim and bend to fit the gap between the Instrument Panel and Side Panel and after 3 tries, I got a shape that worked.
